I've got this far on the N600
Here is where I'm at on the wrecker.
[/IMG]
Not to bad. Will now load it up and take it to the sandblasters. I finished removing the fuel tanks, wiring, and brake lines. They were all bad anyway.
I am going to start taking the engine apart tomorrow to rebuild it. It ran fine, but I like to have it all new so when it goes back together it stays that way.
[/IMG]
Ask the people on here, I dont fall into any slow projects. I have a trailer for tomorrow and it will be at the sandblasters at 1:00 pm. I will be tearing the engine apart to take next door to magnaflux it to make sure it is good. I had it started to I am pretty sure there is no problem. I will rebuild it so I don't have to worry. Went to junk yard today and got new seats for it. I am putting air seats on both sides. I will have to figure out how to get air to them though, do they make a air pump which will run off the battery?>
Hey Kevin, get a small air tank form the wrecking yard. Put a one way valve on it for filling it from the main air system. Plumb it for your air seats. A 5 gallon tank would be plenty, and the air compressor will fill it without any trouble. Then you can run a 1/4" synflex or something line to it. You can put a regulator on it, and keep it adjsuted down. They run to a max of aorund 95-120 pounds for most air seat cushions. They are similar to a suspension bag, but smaller.
MikeWire
26
02-07-2014 11:25 AM
95F350XL
15
05-12-2009 06:03 AM
