2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Rear End
Old 09-03-2008, 10:23 AM
williamsplumbing's Avatar
williamsplumbing
williamsplumbing is offline
Rear End
While browsing through the specs for my Expedition EL, I read that it should be equiped with the 3.73 rear end. Then I read that, that, rear end is discontinued. If I remember correctly, I should be able to discern from the vin what rear end I have. What would be the code for that?
Old 09-03-2008, 11:10 AM
EXPhottie's Avatar
EXPhottie
EXPhottie is offline
16= 3.73
15= 3.31
Old 09-03-2008, 11:59 AM
williamsplumbing
would those numbers be in the vin or elsewhere?
I looked at the vin and neither a 15 or 16 appear.
Old 09-03-2008, 02:41 PM
04markIII's Avatar
04markIII
04markIII is offline
door jamb sticker. look under the word "axle".
Old 09-04-2008, 06:27 AM
chuck s's Avatar
chuck s
chuck s is offline
Second line from the bottom on the VIN plate. Here's mine:
Axle = 16 = 3.73
Can anyone translate the other data? I figured out the 119" wheel base.
-- Chuck
Old 09-04-2008, 11:05 AM
SemperFiDevilDog's Avatar
SemperFiDevilDog
SemperFiDevilDog is offline
If You have the EL then,
You have the 3.73 Rear Axle
Are You saying that You read that Ford is Discontinueing
the 3.73 Rear Axle on the 2009 EL Models?
Old 09-04-2008, 03:01 PM
04markIII's Avatar
04markIII
Axle = 16 = 3.73
-- Chuck
build date 02/07, gvw = weight. separated into front, and rear below the total. tire size/rims size and recommended psi.
ext pnt= exterior paint code
int tr= interior trim code
spr= spring code(1st 2 digits front springs, last 2 digits rear springs.
thats the extent of my knowledge!
Old 09-28-2008, 06:31 AM
SemperFiDevilDog
All EL's have the 3.73 Rear Axle
Grinder Man
1997-2006 Expedition & Navigator
10-10-2014 09:35 AM
mpd579
6.7L Power Stroke Diesel
01-18-2012 09:26 AM
PhilfromFlorida
1999 to 2016 Super Duty
30
04-02-2008 03:50 PM
Quick Reply: Rear End
