What size winch for F250 4x4?
[updated:LAST EDITED ON 15-Apr-02 AT 09:18 PM (EST)]i would go with a 10,000lb. or above winch, that might be a little over kill but it would be worth it, i read somewhere that you need the weight of your vehicle then like multiply that by like 2 or 3, some number like that, anyway, thats what i would go with. im puttin the warn HS9500i on my truck.
1.5 is the min you want. And remember that the winch's capacity is deminished by each wrap of cable. it is the diameter of the spool which become wider and lessens the rotational gearing. I have used a Ramsey RE10000 and never had a problem.
Dusty
Why Buy new when you can build and tailor it cheaper?
F-350 4x4 ext cab Short Bed Green Monster, it is now Sporting a 300HP 715lb/ft Dyno rated 5.9L 12v Cummins diesel w/ NV4500 5spd and custom NP205 ford T-case w/ rear spicer 1410 yoke, Converted to Sterling 10.5 gears w/3.73 gears using the 41 spline pinion and 1410 U-Joints, Power-Lok equipt Dana 60 front, 33's on 16x8" Outlaw II's. (Used to have)205000 miles, Mass air 460 w/ performance heads and a E40d to 5spd conversion and Doug Thorleys. Old EFI 460 @10 MPG to the 12 V @ 23.2 MPG @ 75 MPH and loving it.
My other toy is a '69 CJ-5 354 Hemi 4 spd 4.88's 32x12.50 MThompsons w/ power-lok 44 rear.
Dusty
LeoJr
07-10-2017 07:59 AM
ryanparhaniemi
08-19-2016 09:06 PM
