engine & tranny swap - need a little help
I'm swapping a 302/C6/205 into a 91 Isuzu Trooper. This weekend I finished making the adapters for the motor mounts and I noticed that the tranny sits a little off center. The tranny is offset to the drivers side, is this going to produce any problems with the drive line angle? I looked under a '79 f-150 (same as what this came out of) and it appeared to have the tranny offset, is this the same senario?
Ryan
Ryan
Actually, there was no need for the shoehorn. I installed a body lift about 2 yrs ago so it made for just the right amount of room. The 302 is reasting on the factory 4 cylinder mounting plates, via a set of '70 mustang motor mounts and custom brackets. The C6 is a whole other story. If it wasn't for the body lift it wouldn't fit.
As for the angle on the u-joint, I've herd that it will only handel up to 7 degrees before I start having trouble with binding.
Bob_91SC4x4
08-07-2010 02:59 PM
