Sponsored by: Real Truck
Fault Code
Old Sep 20, 2008 | 09:36 AM
Skreamr's Avatar
Skreamr
Fault Code
Looking for help with a fault code. My 2002 6.8 F250 with 50k miles has just registered a fault code (engine check light) of:
P1633 - (Keep Alive Memory, voltage low)
There was no power interruption, and no recent work done on the Truck, has anyone dealt with this fault code... and where should I go next?
I've run a search (here), without any luck.
Thanks -Jim.
Old Sep 20, 2008 | 12:17 PM
ReAX's Avatar
ReAX
There are a series of fuseable links near the battery, I would probe those to make sure there is not a voltage drop. It wouldn't hurt to check for battery voltage across the fuses too. I have seen a few fuses break but not fully blow, which leads to headaches.
Then I would check the PCM ground, make sure it's clean and tight.
