9 inch rear end converted to posi
Race or street? Race---Spool. Street---locker. I like the strength of both. And the driveability of the locker is not that bad. just have to watch you foot every once and a while. the good thing about the 9" is that you can make gear and carrier changes with out resetting the gears. All you have to do is swap out the 3rd members. So its not like you are locked into what you choose. You can always find a buyer for either. SO....there you go!
Dan "Mudinford" MacDonald
'86 Ford F-150 4x4 w/ a spooled mono Dana 44/a spooled 9" running 38" TSL. 300ci, Clifford Intake and Headders, .05" Milled Head with SBC valves, port work
500 CFM Edelbrock, Clif. 290* cam with Rhoads lifters, .040" TRW Pist w/ Moly rings.
Future plans: A draw through Twin(or big single) Turbo setup (to help with the upper end)
300 Inline turbo plans!?
Here, did some research for ya....talked to about 5 different people....mainly chev people at my dealership i work at....uhuhhhhuhhh.....and asked them the same question you asked here. They all said that posi was the same as LS, just a fancy name. I have seen brake down diagrams of both and they are basicly the same. GM did run a Gov Loc locker.....but that sucker was junk. You want better traction...get a locker...otherwise...just stick with what you have. It will work fine. There you go!
Thanks!
Jim Lee
Received 3,101 Likes
on
welcome to FTE.
since he has not logged on in close to 3 years, i really doubt you are going to get an answer.
you would have better chances getting answers to your questions on doing forced induction up in the six cylinder section of the engine forums. there are still a few guys up there playing with turbos and blowers .
welcome to FTE.
on
Dan never did turbo his truck, and parted ways with it a few years back. He does play with turbos, just not on gas engines.
I also planned on turboing my 300, but, I too never got a round tuit. There is currently a good build in the 73-79 forum that vindicates what I had planned and makes me yearn for another good six cylinder truck to build, but I have not seen under the hood of a 300 powered truck since 07...
