Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
- How to Align Your Tires
Step by step instructions for do-it-yourself repairs
Do it yourself wheel alignment F250 4x4
Pop..I see what you're saying.
If he had nicely just repeated his original question, no one would have taken offense.
It was the repremanding tone he took and the disrespectful way in which he told us to "keep the crap to ourselves" and "sit back and learn something" that we don't approve of.
Some of the guys he was saying that to are some of our most knowledgable, and members who truly contribute to the forum. He has no place taking such a tone with those particular people..just my .02.
Now we're off topic even more.
The guy has a point, however.
We are pretty good at side-tracking the subjects at hand. I do it myself, so let's name me as the biggest offender.
An example: Mention that you've just had a rough shift from third to fourth. How soon do you think that it will be that the thread turns into, "You MUST go to Lead Hill immediately! Do not pass GO!"
Or a question like, "What's a good pre-pump filter?" migrates into, "You must use a regulated return".
Even though I might not have put it like he did, I have some sympathy for the guy's position. He posted here because he wanted an answer. With one exception, what he got were just opinions.
Flame suit on....
Pop
Flame suit on....
Pop
I agree.
Some of the guys he was saying that too are some of our most knowledgable, and members who truly contribute to the forum. He has no place taking such a tone with those particular people..just my .02.
But dont we need a new OT thread since the other ones so big??
I understand most positions. All too often a thread that could be technical and short and sweet explodes... Happens all the time. When I search I find myself paging through several pages just for an inling of information. I would rather a tech thread stay a tech thread and we all get the better from it. Thats my position. I understand you all know eachother and know a lot more than I about "Our" trucks, and only ask to learn.
So anyone with good methods to center up the steering wheel and keep these tires rom scuffing or wearing otherwise poorly please chime in, We're all, all ears.
PS. Good to meet you son...
Welcome to FTE, Dad - you're stuck with a new name, now! (the welcome being intended only due to your low post count, not length of years as a registered member).
Sorry I'm wasting your time by writing stuff you don't want to read, but I just wanted to be polite and give you an official "WELCOME".
Now, back to the topic at hand.... and let's not waste any more of Dad's time folks.
To set the toe raise the front wheels with pressure on the springs ,,blacken the tires with an acetalene torch while spinning
use a scratch all set on a block & scribe the center of the wheel while spinning ...after setting the truck wheels on the ground ,a tape measure will work to set the toe 1/16 to 1/8 neg ,,(narrower in the front) ..Best to be done on tables ,,but it will be close.Tables allow the tires to relax.. If the wheel is off ,,turn the drag link to set it straight .
If the caster or camber is off ,,then you will need special measuring tools for that ,,along with excentric shims( they go in the axle) for the top ball joint ,,,
not really something you can do at home ,,unless you have the equipment to do it ..
BTW , if you are planning to shim ,,also plan on 4 new ball joints , they won't survive R & I...
on
if your so good at doing this type of work then you should already know there is a oval type washer on the top ball joint that can be turned for caster camber, the tie rods take care of toe in..and drag link will straiten the wheel out....i think most all rigs with ball joint are about the same..even though i know how..i still pay the 50 bucks to have it right and have a computer confirm it..these trucks are not a 2,000 pond toy going down the road..there 7 to 8,000 lb PSD built to work....id welcome you to the family ...but thats not the subject at hand and this family don't talk to each other that way...with the free answers you get..a little respect is all we ask for...
on
#29
Sooooo.. Ya, um camber and caster can be adjusted with the upper ball joint eccentric, however they need to be set within a 1/4 degree to make most people happy. basically an alignment rack is need to get that accuracy. I did find a place that sells eccentrics in any flavor you want, including adjustable types, but I ended up taking it to a shop. price goes up with big tires. I have always done my own alignment on lighter vehicles, but heavy 7.3 is another story.
I think bad alignment can cause wheel bearing failures, as there is a horizontal load on the bearing as the driver steers against the pull.
