Ecoboost 2 years away??
I think that everyone could wait 2 years if it puts out the power like this article says. Diesel Superduty power without the upfront cost.
PickupTrucks.com: Update 1 - Ford Ethanol Boost Engine Code Named Bobcat
Yeah the e85 would be a good idea for every petrol station. Also I think that the bobcat would more than likely need e100 if it was mixing in such small amounts. But im unsure.
I'm afraid the Ecoboost will be a warrenty work nightmare, wouldn't touch one for a minimum of two years. Not shure why everyone has such faith in ethanol, its garbage in my book. Ethanol is real hard on carbs, (especially small engines) is hydroscopic, kills mpg, makes gas go bad faster and list goes on not to mention theres not a single station even remotly in my area. I'd much rather see CNG, but avalability is still limited. If the goverment is behind it, its usually a brain fart of an idea.
This article was written on 9-02 08 of this year and they state the EB engines will be available in 09.
Is this information wrong? a 20% boost in MPG is good with the added power and torque.
I'm waiting to see these ecoboost engines before I buy a new F150. You would think this engine would be priority #1 right now for Ford especially since F150 trucks are their bread and butter.
Get these things out now.
E85 can is referenced in the research as the fuel of choice for the bobcat. E100 would be fine too, but E85 is already online and can be used. This technology is already in use, many guys over on turbobuick.com already are using straight E85 to push those 21 year old heavy Buick bricks into the 10's. Ethanol has never been short on power WHEN FORCED INDUCTION is put into play. That's the key though, running 108 octane doesn't help trucks get better mileage unless they take advantage of that 108 octane meaning more boost.
As far as waiting for the first and second generation, I can see that point although if the turbobuick guys can do it, I am sure Ford can put something together...
You [really need to take the time and read the pickuptruck.comarticle. Ethanol will BOOST MPG 20% while supplying 500hp and 700 pnd ft. The vehicle itself would run on regular gasoline only supplying ethanol as a direct injection octane boost if you will. This allows for more boost which is where the increase in HP and torque come into play.
EDIT: It'd be nice if technology could advance enough that an FFV could vary the CR depending on the fuel used. But think that may be a little tough to achieve at the current time.
And the word you're looking for is "hygroscopic" or "hydrophilic." A little of that is a good thing since water in the fuel becomes a thing of the past. If your fuel system or your fuel storage strategy is defective, you may have a problem. No fuel, ethanol blended or otherwise, has stored well since the EPA mandated additive and detergency levels. You need to take precautions and, for long term storage, use a fuel stabilizer.
Ethanol is fine if it's used as intended. No secret that its heat value is lower than gasoline's. That's why it's cheaper. I can get E85 for my FFV Ranger for under $3.00 a gallon. Works better than unleaded for me as the load ping I get with regular unleaded goes away completely.
Ethanol based fuel doesn't last like non ethanol fuel period with or without fuel stabilizer. Stabil came out with a marine stabil to counteract corrosion problems however its not widely available yet. I've been dealing with even small % of ethanol for years in all my boats and other motors and it don't store like plain old gas. The 2 stroke racers have been tearing down there carbs after every race to drain the gas out otherwise the carb will need a new diaphram.
Look at all the past articles, prototypes and etc Ford came up with and never saw the light of day. I highly doubt you'll see a 500hp 700lbft gas/ethanol engine out for a long time or at all. You shure won't see it in an F-150 as that engine is targeted for the SD. Getting all hyped up for a dissapointment IMO.
E85 is popular around the midwestern US however out towards the east coast where I live its pretty much nonexistant. Availability just isn't what it needs to be for widespread use.
I think 3 things everyone would agree with, Ethanol would be a heck of a lot better if:
1. the government and all of the treehugging cronies wouldn't be pushing subsidies left and right for it
2. if they made it out of sugar cane like Brazil, and not corn, as sugar cane is a LOT more efficient. (Ethanol fuel in Brazil - Wikipedia, the free encyclopedia for example)
3. if it was left alone to take off on it's own and not forced via legislature. If the product is competitive enough to take on gasoline as far as bang for the buck goes, it will take off, especially with the whole craziness about gas prices and global warming right now. If it's not, then there's no point in pushing/forcing an inferior product to market
That is all
That is all
