Anyone Install Fender Flares that required Cutting Wheel Wells?
I am thinking about purchasing Fender Flares to Open up the Wheel Wells for added tire clearance. Has anyone done this? If so do you have Pics, advice, info, brand Flares, etc? I want to open the wheel wells up by cutting back sheet metal and will need a flare that can accomidate this type of mod.
Thanks
Thanks
No, I've never done it, but out of curiosity are you planning on making new wheel well liners to accommodate the modified fenders? Lots of electronics under the hood now a days that don't like getting wet. Your IDM (injector driver module) is tucked up above your drivers front wheel well liner, and if that gets wet it will no longer drive your injectors.
I've seen pictures, so I know it can be done, just something to keep in mind.
Look here, Bushwacker Cut Out Fender Flares
Click pic for a larger image
******** type=text/javascript>mboxCreate("keywordRepeater");********* >
******** language=JavaScript src="http://mbox3e.offermatica.com/m2/autoanything/mbox/standard?mboxHost=www.autoanything.com&mboxSession =1221616750078-629540&mboxPage=1221616750078-629540&mboxXDomain=enabled&mboxCount=2&mbox=keywor dRepeater&mboxId=0&mboxURL=http%3A//www.autoanything.com/fender-flares/61A1975A0A0.aspx&mboxReferrer=http%3A//www.google.com/search%3Fhl%3Den%26q%3DBushwhacker+cut%2520out+fla res&mboxVersion=33">*********>
<INPUT id=ProductID type=hidden value=1975> <INPUT id=LargeImageID type=hidden value=4653> <INPUT id=LargeImagePath type=hidden value=http://images.autoanything.com/images/products/med/fender_trim/bushwacker_cut_out_021505.jpg> <!-- Brand Image --> <!-- Medium Product Image --> Sample Image-Your Cut-Out Fender Flares May Look Different
<!-- THIS COMMENT FIXES AN IE6 BUG --><!-- DashKits - Medium Product Image -->
******** type=text/javascript> var page_loaded = true;*********>
<FORM id=vehicleForm>
for everything
View all customer reviews for this product
</FORM>
for everything
</FORM>
