injectors over-fueling at idol
Who is flowing them? I know the people that flowed mine said the same thing. Turns out thier beaker could only hold so much fuel and they rarely dealt with bigger injectors and told me mine were too.. But there was nothing wrong with them.
remember one thing flow testin its not done with your tunig chip and IDM and or pcm controlling it, it just pumps fuel through injector in certain amount of time , thats all.
your injection timing its changed by the guy who is tuning your truck, so the amount of fuel at idle will be changed.
like Tim said it would rev your truck awfully high.....
i have been trying to help rednek99 with his truck. i helped him take the injectors out/in and trying to get the truck to start. and i will tell y'all the condition of his truck. for one it's an early 99 since he doesn't have a sig set up.
here is what we did---
ordered stage 2 single shot kit from diy-injectors dot com, single shot pcm from jody @ dp-tuner, and a dp-tuner chip as well. Roy(rednek99) built the stage 2's himself even though he has never done it b4, but feels confident he did them right. since i know roy to be a good wrecher and when he feels confident it's done right then it's usually done right.
now, after we put the injectors in and filled the hpo rails and hpop res. and put in the dp-tuner pcm and chip we took out the #22 and #9 fuse and cranked it a few times checking hpop res level each time to prime the system. put the fuses back in and it tried to fire a few times, but never came to idle. after that everytime we cranked it we got no fire or anything. got the snap on scanner and did a buzz test and all injectors sound fine. pulled codes and got some pcm codes i believe. we put his old pcm in the truck and cranked it and it fired as soon as the oil pressure guage rose, but never came to an idle. did this everytime we cranked it and it pours white smoke from the exhaust. put dp-tuner pcm back in and it fires when the oil pressure guage rises, but still no idle and lots of white smoke from the exhaust.
Roy talked to both Jody and Jim today and they both think it's a pcm problem and Jody sent him another pcm. hopefully when it gets here the dang truck will freaking start b/c we are really tired of looking at the truck parked with the hood under the shop and not rolling any coal yet. this job should have been finished last week, but we haven't been able to figure out whats going on with it. Like i said, hopefully the new pcm solves the problem
First things first. . . patience boys!! That many changes that quickly can often lead to a little down time for problems. Trust me I've been there. When I first put my first set of Compounds together, the truck wouldn't start. Ended up being that I forgot to plug in the IPR. . . which was nice because it was almost inaccessable. ANyway, white smoke. . . is it oil or fuel? Does it burn your eyes? Almost 100% of the time you change a set of injectors. . . or pull one or more out. . . you are going to smoke oil like crazy for five or so minutes. Keep us updated as to what happens with the new computer.
timmy
timmy
I have been through 2 sets of injectors due to what I felt were unsatisfactory idle problems. In all instances, the truck started and ran. I went back to a DP Tune, (long story, don't ask) it started and idled OK. Even before, just better. Something is wrong. I just wonder if it is the PCM if it ran fine before the swap.
he swapped to single shots and the stock pcm is for splits. we put in the old one thinking maybe he accidentally got sent split shot stage 2's. it didn't smoke at all with the dp-tuner pcm in it while we were cranking it. put in the split shot pcm and it white smoked like crazy and everytime it would fire it would puff black smoke then back to white. i haven't found any loose connections or connections that were not connected back. i checked that first it wouldn't start.
id say that that you took everything out to change injectors, check you IPR wire, it might have been clipped or broken, check ipr nut if its not loose or somthing.... do you get your oil press coming up when you crank? check all the wires and make sure they all plugged in where they should have been
keep us posted
keep us posted
oil pressure gauge comes up after about 3 seconds of cranking maybe. i will check the ipr next time i go over there. the new pcm should be here any day now so i will check everything over real good before we put the pcm in the truck. will be checking ipr, UVC harnesses, etc. one code that we kept pulling no matter what we did was a code for intake manifold heater.. anyone know what that's all about?
