2008 Super Duty Rear Entertainment systems
Does anybody know where the new rear DVD players for the '08 Super Duties are made or by what company. Also wondered if anybody knows of any parts or salvage operations that have any for sale. I looked on Ebay but haven't found anything yet. I like the look and features of the factory model but might end up getting one of the aftermarket units. Also, does anybody know if the factory Ford system can be retrofitted into a 2005 F-250? Thanks.
THey only have "FOMOCO" on the back label as the manufacture and I don't know for sure who makes them for Ford.
There are plenty on Ebay, I just picked up an all black one from an Harley version for only $99. Search for "Ford DVD" and look around at the results. The units for the newer Expeditions etc are the same used in the 08 SDs.
As far as installing one in a 2005 I am in the process of doing that and will post a new thread when I am finished. In order to use it you will need a CAN bus enabled Stereo that has the capabilities of operating it. From what I understand so far you must have a factory NAV system in order to fully operate and control the DVD system. I do not think it will operate standalone.
Thanks FTX. Mine is a 2005 F-250 but I wasn't aware that you had to have the nav system for it to work. If you find that the nav isn't necessary, let me know. I prefer the looks of the factory system over the aftermarket ones. I figured the mounting would probably be the same for the '05 and the '08 as I'm not aware of any changes to the truck's roof structure (i.e. support braces, etc.).
What it will take is some custom brackets going between the 2 support ribs in the roof structure and them mount the DVD unit to that. Not a big deal, but it is a shame because the 2008 mounting bracket is only $40-50 from Ford.
Take a look at these pics and you can spot the difference in the headliners just rearward of the interior light...
Thanks again FTX. I see the difference you're talking about. I really would like to be able to use a Ford system but looks like I'll go aftermarket. It's a shame because I found one on Ebay like you said for $195.00 from a 2007 Expedition. As far as I can tell, it's the same as the one for the SD.
I havent heard of the NAV system being a requirement. When I ordered my 08 I considered the rear entertainment and there was no mention of a necessary upgrade to the NAV system. My wife's Taurus X has the rear entertainment without the NAV. I opted against the factory system (because my dealer told me for the same money I could have 2 seperate screens installed in the head rests and that would enable the kids to watch seperate DVD's if they desired) but if I could do the factory set up for a couple hundred bucks I would.
