Offroad & 4x4
87 Bronco and bumper jacks?
Old Aug 15, 2002 | 07:36 PM
billyb's Avatar
billyb
Old Aug 20, 2002 | 01:13 PM
Tire_Biter's Avatar
Tire_Biter
The factory says its a no-no to use a bumper jack on the 87 Bronco. I sure would like to be able to jack it up without crawling underneath. The attachments does look kinda flimsy. Any thoughts?
Old Aug 20, 2002 | 05:23 PM
rebocardo's Avatar
rebocardo
The bumper is 1/8 stamped (?) steel and I bet a hi-lift jack would either slip off or put a huge dent/crease in it. Most Broncos are pushing 5,000 pounds. The bumper is pretty much for show just like the bumper on newer Explorers and Rangers. It is not a lifting point.
Get a real axle jack with a long handle or real bumpers. The bumper on my BII is 6 x 3 x 1/4 square steel and boxed. There are bolts sticking through on the bottom that help prevent the hi-lift jack from sliding off. Just an idea.
Old Aug 20, 2002 | 11:33 PM
The Man's Avatar
The Man
How is the bumper on an '87 different from a '91 1/2ton??
I use the Hi Lift all the time on my '91 F-150 and the weight is over 6500lbs and there arent any problems at all.
Old Aug 21, 2002 | 08:46 PM
rebocardo's Avatar
rebocardo
I don't know what is on your 91. I do know what was on my 85 and 86 Broncos and the chrome bumpers are not suitable lifting points for a bumper jack. It is a fairly weak bumper that is not up for bumping that bends easy and on the outer end the jack can slide right off.
Old Aug 21, 2002 | 09:12 PM
tellico racing's Avatar
tellico racing
Put the jack near the frame....as opposed to the end of the bumper and it should be fine. I've never had a problem with bumpers bending
78 F150 4x4
429 CID
Dana 44 spooled Front,
9"Locked rear,
5:13 Gears
17/40/15 Gumbo monster mudders
18/39.5/15 Swamper Boggers
BIG,BAD,and UGLY.
Old Aug 22, 2002 | 12:34 AM
rebocardo's Avatar
rebocardo
I could only wish.
Old Aug 22, 2002 | 12:03 PM
Tire_Biter's Avatar
Tire_Biter
I am not so sure that weakness is just the bumper. There is a bracket between the frame and bumper that doesn't look too stout either. If no one can come up with a better idea.....I am considering having a local metal shop make me up some replacement brackets possibly with an integral lift point.
I guess that I was looking for an easier fix.
Old Aug 22, 2002 | 05:02 PM
rebocardo's Avatar
rebocardo
Easy fix, mount a piece of C channel 1/4 inch to your frame that will fit under the stock bumper. Bolt very thing together onto the frame. On the bottom lip near the corners install 1/2 x 3" bolts that extend down to the ground to prevent a bumper jack from sliding off. Cost total is about $50.00.
