How do i shim my fuel filter...exactly!
#31
#33
The schrader valve is next to the black plastic plug
#34
#35
Thanks for your help Cuda, I found it and i'll be checking my fuel pressure next day or two. Can you or anyone tell me the procedure? ie: what rpm's should the fuel pressure be checked at and what are acceptable "normal" pressures. Also, whats the low pressure threshhold where I know I should go ahead and add a BB? Thanks in advance. Ed 95 F-250 model A-215
#36
on
I only have a few friends as it is, and they live hours away.
So, i'm pretty much under my truck, workin on the harley, or dicking with some sorta shearing deal.
Why would you split the profit with me?
I just need you to find a buyer, then i'll sucker ron86toy into hauling it there for me so he can make some money off the guy. haha. =)
Keep this up Cody. your quickly becoming cooler then tim.
Is this the junk I get for not reading one whole thread in this entire Forum......You two run and hide in the corner and bash the living daylight out of me. William you are blackballed, Cody is too cool to blackball so he gets a slide on this one!!
Ed to answer your question I would add the BB if you pressures are under 55 psi. If they are there or over the BB may put it too high but it still might be worth a try. I think 65 is the sweet spot, In my opinion up to 75 is acceptable.
#39
on
EDIT: FOUND IT!!!
http://www.playerappreciate.com/pimphandle.asp
How is this for my newest pimp name?
Professor Truth Beggs Shmoove
#43
on
What? getting a pimp name or the FPR shim???
Sorry....Shimming the Fuel pressure regulator may or may not make a noticeable difference but generally it will give you a little better throttle response. Some claim more seat of the pants power too. Its a small mod but little changes are good that are free.
Now getting a pimp name that is a major change.......
#45
This thread flew waaaaay off the handle a long time ago. But I think we are doing a good job injecting need info along the way.......Treacherous Cuda Luthor....LOL I love it. Some things never get old.
Tim, I like the new name, but you will forever be "Devious Honey Reverend Timothy Smoove" in my mind.
