Trouble starting 04 FX4 5.4L.
Hey guys, how's it going? I just got my hands on a used 04 FX4 SCREW with about 58,700k mi. I've already driven about 300 mi. with it and have been using as a daily driver. Today I parked the truck to speak with someone for literally 5 minutes, came back, when to start it, and it didn't start with two twists of the key. On the third turn, it started.
Is this something I should worry about? What could have caused it?
Thanks guys,
Anthony
Thanks guys,
Anthony
Well, it's DEFINITELY something worth checking out...Something sure caused it to not start right away, and that something could get worse and leave you stranded if left unattended....
I am not that familiar with common problems with these trucks, but there are a couple things to remember here. If you have compression, timing, fuel, and a spark...it HAS to work. So obviously, one of these is a problem.
Sounds to me like a fuel delivery problem...if you have the tools, I'd check your fuel pressures on a cold and warm start-up...
did your check engine light come on? If so, get it scanned, and let us know what code comes up...
Thanks guys,
Anthony
Thanks guys,
Anthony
Okay, AAK...since nobody with more specific knowledge has posted by now, here's how I would go about it...DISCLAIMER: I do not have specific knowledge with troubleshooting this exact engine, so I do not know common trouble spots, or other issues...but I've diagnosed this in other vehicles...so here i go...
You need 4 things for the engine to run: timing, compression, spark, and fuel. If they are all there, at the right times...it HAS to burn! Something here isn't there right away, and I'm gonna guess from what you're describing that it's probably in the fuel system. Not likely the ignition, because you have COPs for each cylinder, meaning one bad COP would not cause you this kind of trouble, and if it were a problem with these, it wouldn't run right once it DID get started.
So, the likely culprit, IMHO is fuel flow. Possible fuel pump or fuel filter issue. Did you change your fuel filter at 30,000 as per the maintenance schedule? If not, I'd get it changed ASAP. How does it run? On WOT? Any hiccups, stumbles, or issues there?
Let us know, and we'll go from here...
Other than that issue with the startup, the acceleration is a little sluggish and the idling is a bit rough.
Thanks guys,
Anthony
Ookay...if it "needed to be replaced"...it wasn't done at 30k...meaning it REALLY REALLY needs to be changed.... I'd get it changed ASAP and go from there...
If it's a bit plugged up, your fuel pump is not going to be able to get good pressure up to your fuel rail right away, thus it takes a bit to get started. Likewise, when you give it some throttle, your fuel pump struggles to provide the fuel injectors enough fuel to accommodate your desired acceleration, causing your engine to run lean under throttle...
From the sounds of it, that should fix your problems.....
Thanks guys,
Anthony
Thanks guys,
Anthony
Motorcraft, Fram, Purolator, whatever...as long as it's a comparable filter, it should do fine.
The only time you really should stick with an OEM Motorcraft filter is when you change your oil filter, as some aftermarket filters don't have as good of an anti-drainback feature, causing a dry start.
Change it, and let us know what happens...good luck!
