1974 Ford Cummins Crew cab
#1231
I have no clue if it's regs or what.
If I have to turn up the compressor for the thing to work better I will. Not there yet though.
I was back in the shop last night for a brief work night. I pulled more of the factory brake lines & fuel lines out and started looking at how I wanted to tie the new brake lines into the existing rear axle setup which I will be re-doing when I put the corp 14 in later.
I also made & welded in the tab for the trailer brake controller.
No pics as I currently can't find my camera
SLOW, but at least somewhat steady progress though!
#1232
I had a short hour or so at the shop on Sat. but it wasn't much time.
I did a little bit more on the brake lines & then ADD kicked in (and some paint was drying on the brake area) so I started to mess with the down pipe again.
Can't remember what brand it was but it's 4" & I got it "used" (new, never installed) off cumminsforum for cheap. Aside from the bend at the bottom which points towards the trans rather than straight back & also ends about dead center on my trans x-member it looks like it was made for the truck. The top bends match perfectly with the floor, etc.
A quick cut on it was all I had time for after bolting it in & looking but I'll get back to it soon.
For now - here's some pics.
Downpipe in
There's about 1/2" - 3/4" gap all along the floor. If it get's too hot I hay have to ceramic coat the downpipe.
The business end of things - getting too much into the tranny's business so a little cutting was needed.
And this is how I left it. I'll pick it back up (literally - it's sitting on the shop floor just like this) whenever I make it back in
Downpipe in
#1234
#1239
Congrats on the engagement...hope you found a good one.
I've spent the last few afternoons trying to figure out my tig welder and so far I have to say that I have a loooong way to go and a whole lot of respect for the nice welds you turn out.
Are you laying down most those welds in one pass? When I try to weld up a piece perpendicular to a flat I end up not being able to get the puddle started before blowing through the upright piece. I try to keep the heat away from the upright until I'm ready on the bottom piece but it just isn't working. Anyway, I have to shut up now.
Sorry
Sorry
#1240
And Chase - congrats! Getting married is definitely an experience.
-Brad
#1242
I can vouch for his chick - she's cool.
#1243
Sorry
Sorry
And on that note - how about an update? It's not much at all, but hey - it's progress. I got a quick hour in the shop yesterday afternoon after getting back from camping and then another short bit this morning before work. I got the hard line for the brakes run down the frame rail. Tonight I go back to the lines inside the cab & hopefully a bit of exhaust too. Then time to buy more fittings/parts before I can make progress again...
#1244
Back to work last night and had another ADD night so a bunch of random, small stuff got started...
1st it was looking at the fuel feed line. Made a bracket for that & figured out how long of a flex line I'd need so I could order it today.
Then I started messing with the dash and brake lines running to the prop valve & line lock.
I put the dash in and really like the prop. valve how I did it.
I'm not sold yet on the other 2 but I'm hoping they grow on me as I am too lazy to redo them. Also I was wondering why the nut I ordered for the line lock hadn't gotten here yet & when I went online to check order status they said the thing was on back order & would ship June 4th. I ordered it about May 4th. I REALLY wish they'd tell you stuff was on back order BEFORE you paid for the order...
Once I got the dash in I started looking at how to plumb this mess. Here's a shot of the stuff behind the dash.
I ran one of the hard lines from the firewall to the prop. valve. & figured out how to do the line from the prop valve to the line lock so I could order that this morning.
I then started looking at running the line from the line lock back to the firewall & out. It was at this point I figured I should start looking at the reinforcing plate for the clutch since I'd have to drill both the firewall & this for the 2nd brake line. I got the thing fitted & most of the holes drilled before shutting down.
I stopped by the hose place on thew way to work this morning & ordered a few custom lines & a bunch of fittings. I need to order my stainless line for the fuel feed & return lines as well as a few other brake lines/fittings and the brake system will be set for now.
More to come soon hopefully.
