Turbo o-rings
Did you guys find a source for the return lines yet? On page 244 of the McMaster-Carr catalog they have some bronze braided hose that would be a lot easier to work with than the PITA return line that comes with the H2E. It comes in different lengths and OD's so you can get the OD to fit the return hole on the plate and then braze a manifold on for the turbo side.I've been gonna redo mine for a long time but now I dont drive the truck much anymore so I'm done spending money on it.
It's just real hard to work with TJ, it corrugated and hard to bend. It you bolt it to the turbo first then it doesn't flex enough so you can plug the bottom into the pedestal. If you preshape it and do the bottom first then either the bottom pops out when you try to bolt it up or you fight it trying to keep the gasket in place and start the bolts. I hate it. Ive have the turbo off 3 or 4 times and that simple little hose is by far the hardest part of the whole job for me.
Yeah.. that looks just like the ones I've seen made up for the H2E
On the HX50 does the return bolt to the bottom of the center section the same as the h2? Cant you just add a street elbo to the bottom to add the length and make it easier to fit the pedestal?
On the HX50 does the return bolt to the bottom of the center section the same as the h2? Cant you just add a street elbow to the bottom to add the length you need and make it easier to fit the pedestal o-ring?
on
1 Post
BTW I am looking for a 17cm non waste gated housing is anyone know of one. the WG'ed housing I have won't work. I was going to block off the WG but the whole deal is just too large to fit well.
On mine there are 6 bolts but they just hold 2 plates down that act as clamps. So in theory (as long as its not rust tight like mine) you can loosen the bolts and rotate the housings. Both my intake and exhaust use this system. I wish the intake we vband but beggers can't be chooser.
I'm sure it can be moved then. My supply line is plenty long and looks pretty good. I think I'd have to leave the center section as is. There is not much room for the 1/2 return. It has to make a right angle the way is sits right now.
It looks like they have the h2e sitting up higher with the kit. Probably because my up-pipes are sitting lower than the stockers?
#28
Not a very good pic but you can see the supply line, the flange for the drain is the same.
#30
on
1 Post
Farm when you say the front and rear are you talking like the supply is pointed toward the fuel filter and the return is pointed toward the firewall? if you so you will need to rotate everything so it more like Rodney's picture. the return is really a drain. It needs to be gravity returned.
