cold weather fast idle questions
It was about 50 degrees here the other morning when I started mine and it never kicked in. Made me wonder if mine had the feature.
I does,
But there are certain parameters that have to be present in order for it to engage. Truck has to be in park, brake pedal not engaged, I believe the IAT has to be blow 32 degrees and the oil temp below a certain amount. Someone will come along and post the exact specifications I'm sure. They are posted at least 10 times a year once fall/winter starts.
I does,
