Shackles or Leafpack on sagging front end????
Well i,m sick of looking at my front end sagging and would like to see it sit level. Got about 150.00 bucks to help Big Poppa. I searched and researched both options and come to the conclusion that about half goes with the leafpack and the other half go with shackles. From what i understand the leafpack stiffin,s up the front as for the shackles let you keep the factory ride. I have 8.50 inches from the top of tire to the dead center part of the fender. The rear measures from the top of the tire to the middle of the fender 9.50 inches. What should i go with, a 1.50 or 2.inch pack or shackle??? And who sells them for a decent price?? Thanks
Well if it's sagging......sounds like your leafs are worn out, and putting shackles will be using the same tired springs. You could get them re-arched for pretty cheap, but it will happen again within maybe a year. Add-a-leave's tend to make it a bit stiffer, but not too bad. My setup before my current lift had an add a leaf in the front, it wasn't too stiff.....the Bilsteins help definitely. I wouldn't waste money on a "high-end" add a leaf, just get whatever is cheapest, it only raises the frontend the thickness of the leaf, not too much performance involved. I think mine was like $80 bucks? Can't remember......OR......you could put that money towards the DP you've been waiting to buy and just pull wheelies, no sag involved
I didn't care for the shackles. I don't like how you can see them pushing down on the leafs. So I took them off and replaced them with the spring pack and I really like the pack. The ride is the same, you can't really see them, and they lifted it about an inch higher than the shackles.
Mighty nice of yaa, i'll give yaa something for them....
Thanks Zack, where else could you go and get this kind of help, very nice of yaa.PM sentSo these should be ok for me???
They are from performance sales online. It is called the 270 Maxx lift. I called and talked to the owner and he was a really nice guy. Gave me a military discount and everything. They shipped super fast and everything went on perfect. I think they cost around $160. They werent the welded together kind either. They come with a new bolt to go through your leafs into the packs.
