Want a tach in a 96 Ranger
My 93 with and auto had a tach in it, you might be able to find one in a junkyard that is in good shape with the tach in it. I don't even think you would have to buy the whole cluster, mine was actually 4 separate plates that snapped together. The tricky thing would be finguring out how to wire it to make it work. The easier, slightly more expensive way to get a tach would be to get an aftermarket one and mount it somewhere in the truck, but it sounds like you don't want to lose the factory look.
Sneak, since your truck has a newer design for the cluster layout than the 93, you'll need to get the whole cluster. The tach circuit should already be in the wire harness and it should allow the tach to work once the harness is plugged in to the cluster. Your 4way flasher should be down by the fuse block under the dash or over by the chime unit which is to the right of the steering column.
88gtblack
08-31-2012 04:09 PM
scottscott
04-22-2010 04:08 PM
