steering wheel off with lift HELP
well i lifted my truck awhile back and the steering wheel was crooked after the install. i never got around to fixing it but now i'm wanting to do that. i was told there is a sleeve to adjust the wheel, but i'm not exactly sure which one to do. here's a pic of underneath and i have two sleeves circled? are these it? and which one do i adjust?
sorry about the gallery sleeve_ediited - TheDieselStop.Com Photo Hosting
thanks in advance.
thanks in advance.
Thats the one. Loosen those two nuts, spray the heck out of it with PB Blaster or any penetrating lubricant, and then pry in the gap with a pry bar (not a screw driver) to break the collar loose. Since you moved the axle farther from the pitman arm, you will probably want to lengthen the rod, since the wheel is turned to the right, correct?
right, so i loosen those up, turn the wheel to dead center, then tighten them back up?
Yep loosen those two clamps on the sleeve...
Key ON with the Engine OFF.
Try to park with the tires as straight as possible.
Engage parking brake.
Loosen the two nuts (15mm I believe) and rotate the sleeve until the steering wheel is centered.
Tighten nuts.
Test Drive and fine tune if needed.
Tighten nuts.
thanks in advance.
thanks in advance.
likeshills08
02-04-2015 03:11 PM
MontanaMan
10-26-2011 06:26 PM
Justin's Green Truck
02-12-2010 05:32 PM
