Speed sensor....GRRRRR
Old Sep 3, 2008 | 11:33 AM
ghunt's Avatar
ghunt
Can somebody tell me a brand of speed sensor I can get for this thing that will actually give me a steady speedo needle? Is motorcraft the only way to go?
Mine wavers a bit with the factory sensor so I can't really use cruise on the highway. I picked up a Borg-Warner sensor at the parts store and it was even WORSE!
Old Sep 3, 2008 | 11:54 AM
LilDuke's Avatar
LilDuke
Maybe it's not the sensor, but the tone ring in the rear?
Old Sep 3, 2008 | 10:47 PM
ford trans tech's Avatar
ford trans tech
if it is a 94 model the PSOM in the cluster could be the issue , the motorcraft sensor is an excellent one and i doubt it is the problem
and as stated before possible tone ring damage or debris stuck to it
Old Sep 4, 2008 | 06:29 AM
alteredspeed's Avatar
alteredspeed
If I'm not mistaking the speed sensor is in the trans or transfer case (2wd vs 4wd). I went through this, its most likely the one of the plastic gears inside of the transfer case (I believe you have a 4wd. There is a 11 mm nut that you can take out and pull the gear out where the speed sensor attaches and also the spedo cable goes in. There should be a colored gear on the end, some times you will find it all chewed up, if it is not stick your finger down in side the hole of the t-case there is also a worm gear in side, it is also plastic, mine was bad, bad news too cause you gotta pull the t-case apart. The sensor in the rear end is for abs and the pcm, but should have nothing to do with the spedo.
Old Sep 4, 2008 | 08:38 AM
ghunt's Avatar
ghunt
Nope the speed sensor in these trucks is on the rear axle.
What exactly is the "PSOM" and is it replaceable?
My Thunderbird has an electronic speedo but it works perfectly, and it has 170K on it. I can't figure out why this one doesn't work right since the truck's only got 95K on it.
Old Sep 4, 2008 | 11:58 PM
ford trans tech
the PSOM is the programable speedometer/odometer module , the instrument cluster
there is one other thing you should check that i omitted
one of the wires at the axle speed sensor should be grounded so that the signal to the psom is only a half sine wave , if there is resistance in this circuit it can cause an erratic signal
you need to check it with an ohm meter
Old Sep 5, 2008 | 11:37 AM
alteredspeed
<table cellpadding="1" cellspacing="2"> <tbody><tr valign="top"><td>^</td> <td>PROGRAMMABLE SPEEDOMETER/ODOMETER MODULE - POINTER WAVER - SERVICE TIP </td> </tr> <tr valign="top"><td>^</td> <td>SPEEDOMETER - PROGRAMMABLE SPEEDOMETER/ODOMETER MODULE - POINTER WAVER - SERVICE TIP </td> </tr> </tbody></table> LIGHT TRUCK:
1992-96 AEROSTAR, BRONCO, ECONOLINE, F-150-350 SERIES ISSUE:
The speedometer needle may waver and/or a light surge may occur on some vehicles when speed control is used at highway speeds between 80-113 km/h (50-70 mph). This may be due to slight dents/chips in either the exciter ring or the Vehicle Speed Sensor (VSS) and air gaps between the VSS and the exciter ring. ACTION:
Replace the Programmable Speedometer/Odometer Module (PSOM) if required. New PSOM's come with increased immunity to system variability. Refer to the following Diagnostic Procedure for details. DIAGNOSTIC PROCEDURE
BRONCO/F-SERIES - Perform normal PSOM diagnostics per Pinpoint Tests "H" and "J" of the 1996 F-Series/Bronco Body/Chassis Service Manual, Pages 13-01-30 through 13-01-32 and Pinpoint "B" of the 1996
Powertrain/Drivetrain Service Manual, Page 10-03-11. ECONOLINE - Perform normal PSOM diagnostics per Pinpoint Tests "H" and "J" of the 1996 Econoline Body/Chassis Service Manual, Pages 13-01-29 through 13-01-31 and Pinpoint "B" of the 1996 Powertrain/Drivetrain Service Manual, Page 10-03-9.
AEROSTAR - Perform normal PSOM diagnostics per Pinpoint Test "K" of the 1994 Aerostar Body/Chassis Service Manual, Page 13-01B-31.
<table cellpadding="1" cellspacing="2"> <tbody><tr valign="top"><td>1.</td> <td>Any slight dents, chips, etc., in either the exciter ring or VSS will create needle waver. Measure air gap between the VSS and exciter ring. It should be 0.38-0.51 mm (0.015-0.020"). </td> </tr> <tr valign="top"><td>2.</td> <td>Check exciter ring runout per the same ring gear backface runout procedure of the appropriate model 1996 Powertrain/Drivetrain Service Manual, Section 05-00. Make sure the exciter ring is mounted correctly to the ring gear. If runout is more than 0.1 mm (0.004"), perform the differential runout check per the procedure in the appropriate model 1996 Powertrain/Drivetrain Service Manual, Section 05-02A or 05-02D, to find cause and repair as needed. </td> </tr> <tr valign="top"><td>3.</td> <td>If all items listed above check good, replace the Instrument Cluster Assembly. Obtain the correct service part number from the Parts Catalogue and then contact the Electronic Odometer Exchange Center at (800) 259-9700 for U.S. Dealers and (800) 663-9974 for Canadian Dealers. </td> </tr> </tbody></table> NOTE : DEALERSHIP MUST TELL THE ODOMETER EXCHANGE CENTER THAT YOU NEED A PSOM3 LEVEL CLUSTER FOR A SPEEDOMETER NEEDLE WAVER CONCERN. OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME
962111A Replace Programmable 0.6 Hr.
Module (PSOM) - F-Series,
Bronco
962111B Replace Programmable 0.7 Hr.
Module (PSOM) -
Econoline
962111C Replace Programmable 0.8 Hr.
Module (PSOM) - Aerostar</pre> DEALER CODING
CONDITION
BASIC PART NO. CODE
10849 06</pre> OASIS CODES: 204000, 204100, 204200, 205000
<!--Start of footer--> <table width="100%" border="0" cellpadding="0" cellspacing="0"><tbody><tr><td valign="top" align="center"><table width="90%" border="0" cellpadding="0" cellspacing="10"><tbody><tr><td></td></tr></tbody></table></td></tr></tbody></table><link rel="stylesheet" href="http://www.alldatapro.com/css/onlineApp2.css" type="text/css">
<table width="100%" border="0" cellpadding="0" cellspacing="0"> <tbody><tr><td bgcolor="#cccccc" height="1"></td> </tr> <tr><td class="footer">© 2008 ALLDATA LLC. All rights reserved.</td> </tr> <tr><td>Terms of Use</td></tr></tbody></table>
Old Feb 24, 2010 | 07:58 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Originally Posted by alteredspeed
10/07/96
Bronco
Module (PSOM) -
Econoline
CONDITION
BASIC PART NO. CODE
ya just gotta love this site.
thanks alteredspeed!
Old Feb 24, 2010 | 11:15 PM
ford trans tech
psom,s are no longer available from ford
Old Feb 25, 2010 | 02:11 AM
starmilt's Avatar
starmilt
Gotta love them ZF5s.lol
Old Feb 25, 2010 | 10:21 PM
ford trans tech
personally not me , manuals are way to expensive to repair or just replace a clutch
BTW , there are speedometer shops that do repair PSOM,s
my nephew had one done a couple of weeks ago for about $350.00
Old Feb 25, 2010 | 10:39 PM
starmilt's Avatar
starmilt
Maybe but I have gone through a few manuals and have to hire the auto's out and I have not had near as much trouble with a manual. and clutches last me longer than most people get out of a vehicle, so they are cheaper for me to run and like them better. lol
Old Feb 26, 2010 | 12:02 AM
tlk50's Avatar
tlk50
You got it Starmilt,
rebuild E4od = $4000
New Computer = ?
Rebuild ZF5 = $2000
New DMF & Clutch = $800
I'll stay with the manual?
Tmarks4323
May 18, 2016 08:26 PM
junkyardjeff
May 30, 2015 08:24 PM
KyEdExpedition
28
Jul 27, 2014 12:19 AM
saltbranch
6.2L V8
26
Mar 26, 2014 01:23 AM
Rafi69
Jul 12, 2011 01:11 PM
