What are used oil furnaces worth? - Ford Truck Enthusiasts Forums
Ontario Chapter Join Chapter>, Leader: loudfords
Old 09-03-2008, 12:19 PM
loudfords's Avatar
loudfords
loudfords is offline
loudfords is a splendid one to beholdloudfords is a splendid one to beholdloudfords is a splendid one to beholdloudfords is a splendid one to beholdloudfords is a splendid one to beholdloudfords is a splendid one to behold
Question What are used oil furnaces worth?
Switching my house from oil to natural gas this fall, and I'm wondering how much I can sell my oil furnace for. It's 9 years old, 78,000 BTU high efficiency, with a 6 year old oil tank. Any ideas?
Old 09-04-2008, 10:37 AM
fp_5's Avatar
fp_5
fp_5 is offline
fp_5 is gaining momentum as a positive member of FTE.
keep it and use it to heat the garage?
frank
Old 09-04-2008, 12:22 PM
loudfords's Avatar
loudfords
When eventually the garage gets insulated and heated, (probably not until I build a new garage) it will be heated by burning wood.
Maybe you should buy it to heat YOUR garage.
Old 09-04-2008, 12:42 PM
fp_5's Avatar
fp_5
fp_5 is offline
I'll be right over,..
Actually, I went electric in my garage, flick of a switch and in a few minutes its comfortable. Got the furnace for free, but then there was that time i forgot to turn it off....., hydro bill just about killed me!
I had considered, oil, propane,natural gas, and wood for the garage but this was cheap and easy(no fuel, no chimeney) since i built the garage with a 200amp service. Oil tanks are a pain and I have no idea what the set up would be worth. Now is the time of year to sell it though.
I had heard that hi efficiency oil was actual very economical. The efficiency % is lower than natural gas but oil burns hotter so it makes up for the difference in efficiency rating. Then again, a barrel of crude oil was a lot less when I was looking into it because gasoline was nowhere near $1.30/litre.
You should have no problem selling it where you live, someone should be able to use for there home or a garage/outbuilding.
Frank
Old 09-09-2008, 07:37 PM
falconqueenD's Avatar
falconqueenD
falconqueenD is offline
falconqueenD has a great reputation on FTE.falconqueenD has a great reputation on FTE.falconqueenD has a great reputation on FTE.falconqueenD has a great reputation on FTE.falconqueenD has a great reputation on FTE.
try the fossil fuel depot ,yuk yuk yuk
ALSO MY DOGMA RAN OVER MY DOGMA OOOUCH!!!!!!!!!!!!!!!!!!!
Old 09-12-2008, 12:14 AM
mikeyswood's Avatar
mikeyswood
mikeyswood is offline
mikeyswood is gaining momentum as a positive member of FTE.
I have a two year old gas Weil Mclain that I have removed from my house if you haven't bought one yet.
Mike
Old 09-19-2008, 07:33 PM
garywh
garywh is offline
garywh is starting off with a positive reputation.
lm a furnaceman semiretired and yur tank and furnace should get $200,,,thats all folks
Old 09-22-2008, 01:02 PM
loudfords's Avatar
loudfords
Thanks Gary. Better than 0, I guess.
lemonshindig
General Diesel Discussion
42
03-09-2015 02:56 PM
CortStrasser
02-16-2015 08:13 PM
Nitramjr
12-05-2013 11:57 AM
ford2go
10-28-2013 09:53 AM
Ford79
Garage & Workshop
02-09-2006 10:07 PM
Quick Reply: What are used oil furnaces worth?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
