new guages
Old Sep 1, 2008 | 08:56 PM
guitarnik's Avatar
guitarnik
new guages
has anyone used or heard anything about those aftermarket oil pressure, water temp and voltage guages that they sell at autozone and oreilly and the like. good bad worth it?
Old Sep 1, 2008 | 10:39 PM
Jason Lewis's Avatar
Jason Lewis
I got three and thay have a more accurate reading than the stock gauge
i got oil,water,trans. all electric auto meter. Thay are good to have for high mileage vehicles
Old Sep 2, 2008 | 08:05 AM
guitarnik's Avatar
guitarnik
thanks, by the way where did you mount them?
Old Sep 2, 2008 | 08:11 PM
Jason Lewis
A Pillar
Old Sep 2, 2008 | 08:24 PM
N8N's Avatar
N8N
I added some gauges under the dash of my '93 F-150, I had an old Auto MEter 3-gauge panel bracket kicking around so I just stuck it to the bottom of the dash with 3M double sided tape. I used oil press, vacuum, and trans temp (I wanted the oil press and trans temp for sure, I just bought a vacuum gauge to fill the other hole. Stock voltage and temp gauges seemed to be OK but I never could get the oil press gauge to work properly.) Two gauges were cheap Sunpro gauges and the trans temp I had to get from VDO, only they made one in the style I wanted. I can say that the backlighting on the VDO gauge is way superior to the Sunpro gauges, if I had it to do over again I'd go with all VDO. Auto Meter and Stewart-Warner are also good brands but I haven't used any of their recent products. The Sunpro gauges work fine they are just hard to read at night because of the way they're backlit. I had to put brighter bulbs in them and even so they are still hard to read because when you look at them at an angle you get a lot of glare from around the edges. Auto Meter makes little silicone light bulb covers so you can change the color of the gauge lighting to match your dash. I know that I have used at least the red (in my old Studebaker) and green (in the F-150) and those work fine.
nate
Old Sep 3, 2008 | 03:48 PM
guitarnik's Avatar
guitarnik
thanks guys, i think ill get some
