7point3 site, what's wrong?
Old Sep 1, 2008 | 07:54 AM
farmdad's Avatar
farmdad
My son is stranded in OK with his truck not running well. He has checked the usual possible problems but so far, no luck. I'm trying to log on to the 7point3 web site to see if someone in OK is near him and could help but the site seems to not be available. Does anyone have any info about the site? Thanks for any help you can give.
Old Sep 1, 2008 | 07:57 AM
1996pwrstrk's Avatar
1996pwrstrk
I have tried to get on it several times lately and have only been able to once . Where is he at in OK ?
Old Sep 1, 2008 | 08:03 AM
farmdad's Avatar
farmdad
I think he said near Springer on I35.
Old Sep 1, 2008 | 08:21 AM
F350-6's Avatar
F350-6
7point3 has been down for a while. Maybe you can find a moderator and change your thread title to Help in OK, or start a new thread to get a locals attention.
Can you tell us what's wrong and what he's tried so far? Maybe we can offer some suggestions.
Old Sep 1, 2008 | 08:26 AM
ron's power stroke's Avatar
ron's power stroke
Rich (white Buffalo) is from ok and is on line right now
here is his profile https://www.ford-trucks.com/forums/m...oster&t=771211
Old Sep 1, 2008 | 08:30 AM
1996pwrstrk
Thats a little to far over for me I have to work tonight.
Old Sep 1, 2008 | 08:31 AM
farmdad's Avatar
farmdad
Chris, found your thread about the UVCH problem that you had thinking I would have that info when he called again. He has checked the oil level in the engine and HPOP, checked some of the wiring but I don't think the one you had trouble with, is checking the nut on the IPR, said the truck will run fine when he starts it and then starts to lope and go to a slow idle, hasn't died yet, doesn't smoke, has good fuel pressure on his pressure gauge which is after the filter, didn't say if there is response to the fuel pedal or if it has enough power to move.
Old Sep 1, 2008 | 08:38 AM
F350-6's Avatar
F350-6
Don't forget to check the air filter, and see if he recently filled up. Maybe a bad tank of fuel? I'd agree checking the pedal assembly sounds like a good idea. Dropping down to idle sounds like it may be TPS related.
Old Sep 1, 2008 | 08:43 AM
farmdad's Avatar
farmdad
Ron, thanks for the tip. I PM'd Rich. Just got a call and guess we are going road tripping to OK from Iowa. He is running out of ideas.
Old Sep 1, 2008 | 09:47 AM
farmdad's Avatar
farmdad
Next installment of the continuing story....... farmb0y had been to Tony Wildman's to do live tuning which I hear was very successful. He was on his way back home when the problem developed. He has been in contact with Tony and they determined that the problem may be a bad injector on the passenger side. Tony is on his way to the rescue with tools and another injector to try to get it running well enough to get it home. White Buffalo has been in contact with farmb0y, Tony and me so there is help on the way. Just hope that nothing too serious is causing the problem.
Thanks for all the help and advice. I was wondering if anyone would be on early this morning and was pleasantly surprised.
Old Sep 1, 2008 | 09:53 AM
ron's power stroke
glad he has help on the way..hope they get him going again....we need to something with the 7.3 road side...there has been to many times we have needed it....
Old Sep 1, 2008 | 11:07 AM
megawatt00's Avatar
megawatt00
I have heard that AMiller has been really busy at work and other things. He had posted a while back about the site going down for maintence and it never came back up on line.
I was thinking of making a list and sending it out to everyone, kinda like the RHN but on a form that you can keep on your computer or print out. What do you guys think??
Old Sep 1, 2008 | 11:14 AM
tag187's Avatar
tag187
AWESOME idea Megawatt I realy hope it works out. Reps to ya for it.
Old Sep 1, 2008 | 11:26 AM
megawatt00's Avatar
megawatt00
Thanks Tag. Lets see what everyone else thinks. It may take a little while to get all the info and to put it together but it can be done.
Old Sep 1, 2008 | 11:37 AM
ron's power stroke
i think thats a great idea Jim...lucky for me i copy and pasted the phone## and addresses off of the 7.3 road side...but dont give any of that info out..there was an agreement when that list was made and i stick to it....
