Maryland Chapter Join Chapter, Leader: BPofMD
Where is our John Deere tech?
Old 08-30-2008, 05:10 PM
80351's Avatar
80351
80351 is offline
I know we have one here somewhere cause I just
approved his membership.
Need some help.
Old 08-30-2008, 05:49 PM
sglaine's Avatar
sglaine
sglaine is offline
Posting Legend
Maybe I can help Dave...Give it a shot
Old 08-30-2008, 06:25 PM
80351's Avatar
80351
80351 is offline
Belongs to a friend but I got a Scotts rider Kohler Commander 16. The solenoid went up on so I wired it up for a starter button direct about 2 years ago. Has been working fine. He called said it quit again smoke came from the button and wouldn't start.
Got it home, won't start with new button, solenoid is shot but if I jump it it will crank but no fire to the plug. All the safety switches seem to in the go position even the seat but still no go.
How do I jump these switches, do I just use a jumper between the 2 polls?
Old 08-30-2008, 06:31 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,098 Likes on 998 Posts
That will certainly jumper the switch.
Old 08-30-2008, 06:32 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
How many pins on the switch?
Old 08-30-2008, 06:36 PM
80351's Avatar
80351
80351 is offline
Some are 2 a couple are 3.
BPofMD's Avatar
BPofMD
BPofMD is offline
Single pole or double pole?
. or
Old 08-30-2008, 06:37 PM
sglaine's Avatar
sglaine
sglaine is offline
Posting Legend
On my old Deere there are 6 pins on the switch
BPofMD's Avatar
BPofMD
BPofMD is offline
If more than two, you need wiring diagram....or figure where the wires go....
Old 08-30-2008, 06:40 PM
80351's Avatar
80351
80351 is offline
That's exactly what I need. Are we talking about how many polls are on the the safety switches, ignition switch or solenoid?
Old 08-30-2008, 06:43 PM
80351's Avatar
80351
80351 is offline
Ignition switch has 5,
soleniod is 4 just like a Ford
seat switch 2, deck switch 3, brake switch 2
Old 08-30-2008, 06:45 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
You can jumper the two 2 wire switches straight across to eliminate a bad switch....I wouldn't think that the deck switch would stop it for starting....
Old 08-30-2008, 06:49 PM
80351's Avatar
80351
80351 is offline
OK, I'll try that.
BPofMD's Avatar
BPofMD
BPofMD is offline
Sounds like the starter button you put on burned up for sure....what else it took out is a ?. The selinoid should have been replaced as you were putting real high current through the button without the selinoid....amazing it lasted that long!
Old 08-30-2008, 06:52 PM
sglaine's Avatar
sglaine
sglaine is offline
Posting Legend
I had a simuar problem a few years back Bud..And you nailed it to a T..
Quick Reply: Where is our John Deere tech?
