18.3 miles per gallon
i had to double check the numbers. last week i filled my truck up at a Sam's (wal-mart) gas station with the regular 87 octane (only 10% ethanol)
so after 346.2 miles i go back to same station and same pump and fill it up again. it took 18.863 gallons to fill it up, so if i did my math correctly that should come out to 18.3mpg.
f150 extended cab 4speed auto 3.27rear, 4.6 v8 and has a camper top.
i wasn't running the ac much and mostly driving back roads and highways (not much above 60mph)
does this sound about right. it usually only gets about 16mpg
JL
I have a '03 Screw with the 5.4, 3.73 gears, and still stock Wrangler tires. I recently added the ScanGauge2 so I can see my mileage quite easily. Highway mileage at 65 has been running about 17-18mpg. And that's on E10 gas.
If i drop to 60mph, I get 18 pretty solid. Assuming it's not windy out.
I just got 18.8!! My best ever!!! & that was hauling a load of sawdust out of Kentucky & Across Jelico Mountain. Average speed 70 -75 with 87 Octane 10% Ethanol. Food City gas I do not know where they get their gas from but my truck likes it.
I just replaced the Old General tires that were on the truck when I got it & put on a new set of Michelin LTX M/S. I have yet to go thru a tank of fuel to see where my mileage goes but I have been driving a bit faster than normal with the new tires. Man It will hold a curve now!
