Idle problem!
Old Aug 22, 2008 | 09:16 AM
Dre82s's Avatar
Dre82s
Idle problem!
Hey guys, so I have this pesky little problem with my truck. I have replaced the TPS, plugs, did the timing, rotors, distributor cap, EGR sensor, Idle control motor was cleaned up. Truck is not shooting any code and the idle is high at all times sometime is drops below 1300 rpm but usually stays around 1500 what could it be? any answers I'd appreciate it.
Old Aug 22, 2008 | 09:25 AM
andym's Avatar
andym
Sounds like a vacuum leak to me.
Old Aug 22, 2008 | 09:58 AM
quicklook2's Avatar
quicklook2
or you need a new iac.
cleaning rarely fixes them.
Old Aug 23, 2008 | 10:41 PM
jacked87f250's Avatar
jacked87f250
I had the same problem with my 91 it is most likely a vac leak!
