In my quest to re pad the rear rotors on my 04, I contacted B&C Car-quest. They list a couple of kits to accompany the job. One is a slide pin kit that includes pins and bolts, and the other is boots,retainer springs, and anti rattle clips. Has anyone had there hands on with either of there offerings? Are they worth the salt or should I go OE, to have the whole enchilada, so to speak?
The heads of the car-quest slide pins(in hand) have got the same flaired tops, unlike OE that have a notched upper pin head for the upper slide? There slides have three small flats around the shaft, i'm not sure if OE has this feature or not.
we'll tell you that runescape money you were born in Britain's last Asian colony in the lunar year of the pig and that when we brought you home, the staff of our apartment block gathered to wish you well. We Chinese runescape gold love boys. One man said you were the first baby to be born in the block in the year of the pig. This, he told us, was good Feng Shui, in runescape power leveling other words a positiveRunescape Gold sign for the building and everyone who lived there.
Let me see if I can spell this out for you. F-o-r-d T-r-u-c-k F-o-r-u-m.
I got the old ones out fine. They had no corrosion (drivers side so far). The new pins have a gold colored plating and I'm not sure of its composition. All I can figure is that ford engineers figured one pin ( maybe compression side) needed full surface contact, but that would seem to limit available grease. I may be looking to close, and aftermarket had to do something to avoid patent infringement? ironmine thanks for the chat back.
