Truck started running "different"
Just a bit of background, for several days now my truck would run normal as the engine was warming up to operating temps. After the truck was fully warmed, I started losing power. Take-off from a stoplight was slow, sluggish, and there was no throttle snap. Top end power and boost was dropping. If I romped on the pedal, it felt like it was defueling. Also the truck didn't want to downshift such as when passing, etc. None of those symptoms are present if the engine is still cold.
So I plugged in AE and ran some tests. Everything is normal. Started monitoring live data and found that my coolant temps were off - way off. Gauge showed normal (as normal as it always does for the Ford factory dummy gauge, meaning dead center and never moving), but under AE my coolant temps were reported at 280 degrees
Started wondering if the gauge was wrong, or if it's just the PCM is seeing the wrong temps, so I checked the oil temps. That was only 207 degrees (oil temps are normally only slightly above coolant temps), so I figured by that report that the PCM is seeing the wrong coolant temps and is putting itself into a kind of limp mode. That would explain why the truck runs normal as the engine is still cool, and falls on it's face once it reaches operating temps.If I remember to do this, then tomorrow morning I'm going to hook AE up again and look at coolant temps before cranking the truck. I just want to get a baseline to see if it's reading some funky number before the engine has warmed up.
As for a fix, I guess I'll need to swap out the coolant temp sensor. I have never paid attention to where it might be located. I'm guessing somewhere near the thermostat??
Anyone know for sure?
There is also a temperature sender gauge switch if you need a picture of it.
Click on link even though it says unavailable.
I assume you have an automatic....
The wiring diagrams for an '02 show that the coolant temperature sensor is ONLY used on manual transmission-equipped trucks. The TFT (transmission fluid temperature) sensor is hooked to the circuit that WOULD BE the ECT (engine coolant temp) sensor on a MT truck. The TFT, IAT 1 and 2, and EOT are the ONLY temperature inputs on your AT-equipped truck.
However, what I'm wondering is if that is for the gauge only, or if there is something else I'm missing. The reason is the gauge temp never moved past halfway, yet the PCM was seeing coolant temps well beyond what would have fried my engine. I'm just thinking about that discrepancy and trying to figure out what I'm forgetting here.
The Engine Coolant Sensor is used as the primary input to the Electronic Control System to enable adaptive cooling. This provides a means of providing adequate cooling in severe engine temperature conditions. When ECT is greater than 107°C (225°F), the fueling rate of the engine is modified to provide cooling protection and prevent engine damage due to overheating.
Edit: Good catch on the coolant temperature reading being your problem. That's probably the last place I would have thought to check.
Can you just unplug it and see if truck runs better? Or will it error.
Or maybe pull sensor, toss in a plug and take for a test ride while it is dangling to make sure before you spend the money.
Man, I got to get an AE.. It is on my santa list.
Yes indeed. Good catch.
Check these two wiring diagrams. You will see the manual/automatic differences. Pin 37 is the input to the PCM on the orange w/black tracer wire.
On the second picture, the continuation at "K" shows the splice to ground. This is from ALLDATA.....and these are ACTUAL Ford diagrams.
Don't take it as gospel....it's just a representation.
