3 valve 5.4 cam timming - AB, Canada
hey gang. im new to the site. i was looking for some help.if posible. i removed the cylinder heads and reinstalled them and the the timming chains as per the shop key ilistrations. it wont run propper it is low powered and pinging bad. cant get over 35mph. i scanned and its giving me rich drivers bank and lean pass bank codes. it feels like the cam timming is still out a tooth. but with the varible rate cam shafts how do you know if they are advanced or retarded when installing the chain?? can they be zeroed for correct install?? now i have a truck i cant drive. i have tried 5 times and still the same outcome. anyone have any ideas? any 3 valve gurus?
on
Hi billlt583, welcome to FTE!
Try posting your questions in one of the site's tech forums. One of the members can assist your there.
Try here,,, https://www.ford-trucks.com/forums/forum48/
Or maybe here,,, https://www.ford-trucks.com/forums/forum47/
Check our the Alberta chapter of FTE when you get a chance,,,, Alberta Chapter - Ford Truck Enthusiasts Forums
galefowler
New Member Introductions
10-05-2008 06:27 PM
