To Shift or Not to shift: That is the question
So in the past week I have gone about 3 hours north of here 3 times to pick up three horses... All went great. The truck pulls wonderfully and of course has plenty of power. I just wanted some opinions of pulling while in "5th/OD" I have herd alot of opinions from random people, but of course my friends here are the ones that i listen to when it comes to my baby. 4th gear @ 55mph is just over 2200rpm. I know thats not high or going to hurt anything. BUT IF I happen to want to go fast say 65mph or so then thats pushing 3000rpm. 5th gear @ 65mph is just around 2000rpm. I don't try and go up hills while in high gear but some of the nameless people I have talk to say it doesn't matter you shouldn't use high gear when pulling at all. Anyways look forward to your response's.
Just a reminder its a manual 6speed with 33" toyo's.
You're pulling what, 8 - 9k? Put the thing in high gear and down shift for the hills if you need to. I don't really have hills here (at least more than a mile long or so), but I tow in 5th (some call it 6th) all the time.
If you can maintain speed in 5th gear then you don't have to worry about down shifting. Your speedo will let you know when it's time to down shift. I towed some gravel home in a dump trailer a couple of weeks ago. Trailer and gravel were about 23k (woops) and when I got away from traffic and could increase my speed, I put it in the OD gear.
You're not going to hurt a stick shift driving in a higher gear, you just want to make sure you're at a decent RPM to keep in the right spot on the HP /TQ curve. The autos have issues in OD because the tranny will hunt back and forth between gears in some cases and either overheat the tranny or burn up the torque converter. We don't have those issues.
