1994 ford 460 in Rv rear main seal help!
I’m replacing my rear main oil seal
in my R.V ( Firan Raven 1994 ) It’s a Ford 460 engine ! Without pulling the entire engine out ! But only pulling transmission and raising the engine enough for clearance of the oil pan to access the rear main cap ! I have been only able to get just enough clearance to back of the oil pan to pull the rear main cap ! ( but oil pan not fully out) In order to extract the top main seal would I have to totaly pull out the entire oil pan and loosen all the main crank caps so to extract and install the top rear main seal ? Or is the top rear main seal loose enough when pulling the rear main cap ? Also do I need to add sealant between the top and bottom cap ? Please help on any suggestions for the above questions : sincerely John white ( jrwhite3330 )
https://www.ford-trucks.com/forums/1...main-seal.html
This is a 95 460. It is a 2 piece rear main seal.
Bullet Bob Anderson
23
04-29-2015 04:50 PM
quakerj
90
01-04-2014 07:40 PM
w6pea
09-16-2011 10:12 PM
Phil527
09-09-2010 10:07 AM
Bluegrassboy70
11-06-2009 11:06 PM
