75w-140 vs. 75w140LS
I am changing the rear differential fluid in my 2001 F150 w/LS. Ford specifies 75w-140 synthetic and with a friction modifier. I see 75w-140 synthetic both "plain" and "for LS". I assume the only difference is the presence of the modifier (ie., it would not be necessary to make any add).
Is that correct, or is there another difference? My reason for asking is that I would like to use the plain oil and add less of the modifier in order to get the maximum limited slip.
My understanding is that the additive reduces chatter and grabbing by lowering the limited slip action. In other words, moving towards a conventional open differential. So if there is too much additive, there would be no obvious problem, but there would be little or no lock-up.
Did you decide you needed more because it was still chattering?...and under what conditions? (I'd like to have max limited slip even if it sometimes chattered a little).
Can anyone confirm that the difference between 75w-140 synthetic and 75w-140 LS synthetic is just the presence of the friction modifier?
BrianA
06-16-2016 05:27 AM
raptor131
09-15-2009 09:31 PM
aplustechnician
17
12-09-2005 01:01 PM
