In addition to blowby, rough idle, and so much more!!
So the blowby post didn't yield any results, but is still an issue with this new truck. In addition to the blowby issue it also has a cold start problem. I have checked and replaced the valve cover gaskets, uvc's, and the guy I got the truck from just had the gp's replaced. Changing the uvc's helped the rough idle issues some, but it still has a slight miss and a hesitation. He also had a new turbo put on it, not completely sure why. If the old turbo quit or scattered this could explain some of the other problems. One thing that I am having a problem with is that the WTS lamp only comes on for maybe 5 seconds regardless of the temps. It has been down into the low 40's this week in the mornings and I have been letting the gp's run until the volt meter has come back up and the gpr has kicked out. It has a new alternator, batts, IPR overhaul, still needs to have the CPS recall done on it. Any help getting me started on the right path would be great. I have all of my performance goodies ready to install, but want to take care of the basics first.
Thanks, Justin
Thanks, Justin
