magnetic guages
Guest
Posts: n/a
magnetic guages
I have not worked on anything as new as a 92 but on older ones you can
take the wire off the sender and ground it and if it pegs the gauge the gauge is ok.I think this will work on yours.Is this one of those
that you have to replace the gauges in pairs on?Hope this helps
Larry
Larry
magnetic guages
Fuel guage testing. Install in place of sending unit 10 ohms resistance from guage wire to ground with key on. Should read full or above by 2 pointers width. Install 73 ohms resistance. Should read empty or below by 2 pointers width. Temp guage, 10 ohms is hot, 73 ohms is cold.
magnetic guages
Hey guys, thanks for the information. I hope this doesn't seem to silly, but I'm new at the electrical end of things and had a couple basic questions. 1.Is the resistor just a piece of wire with a certain resistance, or is it something I need to pick up at the parts shop. 2.Do I have to attach the resistor directly to the battery ground, or will the frame of the vehicle do. Thanks again!
Phil
Phil
