Aftermarket roll pans
If you plan to remove the front bumper...you might want to check your state laws first. I have recently found out it is illegal in quite a few states to do so and drive them on the highways.
Yes...I know they sell the front roll pans without openings. That does not make them legal everywhere though.
As far as who is recommended to get them from...no clue. I have never purchased anything like that. I get most of my smaller parts from Mid-fifty.
There are several around here who have tucked their front bumper in against the stock pan. I think they leave an inch or two clearance. You would have to run a search to see what threads they are in as I do not recall.
and I am also using the rear pan (without lights).. this rear pan required extra work, as the edges were not finished.
you can see them in my gallery in the paint section.
Sam
MAR-K has steel rear pans for this and many Ford trucks.
There is a thread on the site of someone who just posted pictures of our rear pan:
https://www.ford-trucks.com/forums/7...e-weld-in.html
Also, you can go to our website and see pictures of some on our customers' trucks:
http://www.mar-k.com/ford_truck_gallery.html
You can order them at
http://www.mar-k.com/catalog
Hope this helps.
Hope this helps.
When you cut your frame horns off, make sure to save them so the guy that ends up with your truck can weld them back on.
Dave
http://www.roadsters.com/56/
Dave
I like very much the look of my front end without a bumper. I used a fiberglass gravel pan that I got from John's F-Fun Hundreds (in Anaheim), but I wouldn't recommend it. This one was laid up too thin and I needed to do a lot of work to heavy it up. If you can afford the metal one from Mid Fifty, that would be a better choice.
I also like the look of a rear roll pan, but I wanted something with rounded corners and couldn't find any like that, plus my bed is 4" wider than any stock one.
I just narrowed my bumper and used hugger brackets to tuck it in. I think it keeps the protective function and looks pretty good.
Good luck on yours.
Good luck on yours.
ultraranger
11-01-2014 10:05 AM
caleballen95
05-21-2014 05:47 PM
chincycoot
08-30-2013 06:47 AM
