Oil Cooler
Old Aug 9, 2008 | 09:21 PM
DND58's Avatar
DND58
Oil Cooler
Hey guys, I could use some advice. On a 1988 F-250, 460, manual trans, in front of the radiator, is another small radiator. I've tracked 2 hoses back to the oil filter assembly. Leaking oil from the small radiator. Is this an oil to air oil cooler? Can I just remove and take to radiator shop for repair? I can't find much info on this. In advance, Thanks.
DND58
Old Aug 10, 2008 | 07:00 AM
phoneman91's Avatar
phoneman91
I would think that the cooler could be repaired like a radiator. Call some radiator shops in your area and verify that they can repair it before removing it.
Does it look like an aftermarket cooler?? I didnt know that Ford had oil to air coolers for engine oil.
