Timing Mark Issue
Old Aug 9, 2008 | 05:30 PM
skierkid's Avatar
skierkid
Question Timing Mark Issue
In the process of heads, had heads redone at shop. Reinstalling heads and attempting to time the engine. I have followed the Haynes manual instructions and put 1 piston at TDC.
Issue
the manual says to align the keyways on the cam sprockets perpendicular to the valve cover surface on the head. when done the timing marks do not line up they are 180 degrees out.
if anyone has done this or has any insight it would be greatly appreciated
Old Aug 14, 2008 | 08:52 PM
70f100longbed's Avatar
70f100longbed
Read my replies here https://www.ford-trucks.com/forums/7...g-a-5-4-a.html I'm a Ford engine master tech and that's how I time a 5.4 and have never had a problem.
Old Aug 15, 2008 | 12:50 AM
LastSplash's Avatar
LastSplash
Rotate the crank i full revolution and see if the marks line up.
Old Aug 15, 2008 | 06:56 AM
70f100longbed
The problem with that is the marks on the chains will not line up with the cam and crank. Eyeballing the timing chains is not a good way to do it.
Old Aug 15, 2008 | 12:48 PM
skierkid's Avatar
skierkid
Thanks for your help.
I ended up getting directions from the Romeo Engine Plant.
The right method is crank timing mark @ 6 driver side cam @ 12 passenger side @ 10 then line up the marks on the gears with the chain marks.
dahr85
Jan 26, 2012 03:04 AM
CR's Ford f250 SD
Jul 9, 2011 02:43 PM
crazed87bronco
Jul 6, 2011 01:47 PM
Flame Out
Jun 6, 2008 01:58 PM
bigwin56f100
Feb 17, 2004 06:59 PM
