Sponsored by: Real Truck
Dash is going nuts
Old Aug 6, 2008 | 11:00 AM
DIESEL DENNY's Avatar
DIESEL DENNY
Dash is going nuts
99 F 250 P/S 4X4 125.000miles
Speedo goes nuts after about 30mph - ABS light is on & the overdrive light wont go off ???
Old Aug 6, 2008 | 01:01 PM
ReAX's Avatar
ReAX
I'd suspect the VSS is failing. VSS is your vehicle speed sensor, its mounted on top of the pumpkin. This one sensor sends your vehicle speed to your speedo, trans and abs system.
Old Aug 6, 2008 | 01:16 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I agree with what was said. You might try taking the sensor off and clean it and the connection. If that don't work, NAPA has them. NAPA calls them the ABS sensor.
Old Aug 6, 2008 | 01:25 PM
miller_feed
You need to get the codes read and post them here.
Old Aug 6, 2008 | 03:25 PM
DIESEL DENNY
Sorry for being stupid (PUMPKIN
Old Aug 6, 2008 | 03:29 PM
ReAX's Avatar
ReAX
The middle of the axle housing that contains the ring and pinion.
Old Aug 6, 2008 | 03:35 PM
DIESEL DENNY
aaaaaaaaa nOW i FEEL REAL STUPID
ltng7679
Jan 17, 2015 04:25 PM
Gas Guzlr
Jun 2, 2014 11:06 PM
00GT
Escape & Escape Hybrid
Sep 3, 2011 09:17 PM
mopower
Sep 17, 2004 12:19 AM
98 4.6 locked up
1997 - 2003 F150
Apr 3, 2004 07:20 AM
