Rear brake line connection-95 Ford F150
The saga continues, did Ford use loctite on the hollow stud in the hydraulic brake line?
The nut that's on there is stuck to say the least. If I only had a brain I would of gotten one on the last run for parts, but, that will be tomorrows mission. So far everything has gone pretty smooth. Does anyone know why ford has different sizes of line fittings on these?
The part's a pretty standard part at most FLAPS. As for the fittings, yeah, we just bought this truck, but it seems like one of those where one department had gone metric, and another hadn't, so there'll be SAE on one end of a connector or line or brace or something, and metric on the other. The problem is not alcohol per se, it's more like the designers in the various departments didn't drink at the same bar....
nebechanezer
04-14-2005 08:01 PM
