You guys and FTE Rock!!!
I was removing a rear fender this afternoon and one of the bolts spun on me. Fortunately for me I had read the "Tips and Tricks" thread and remembered someone had mentioned tack welding a bolt head to keep it from spinning. It saved me hours of frustration and bad language and only took 5 minutes to set up and accomplish.
Thank you.
By the way the screw type RV levelling jacks are working just fine. I have the truck level from side to side with a little bit of rake towards the front.
I am almost ready to remove the bed. The only problem is the 6 bolts with square holes in their heads. The holes are larger than 1/4 drive and smaller than 3/8 drive. Is there a special tool or should I just grind down and old 3/8 extension and use it to hold them from turning?
Thank you.
Make-a-Tool Time...
Laterb Man...
I've removed these bolts by grinding an 3/8" extension. It worked fine but eventually broke. I removed quite a few of these bolts before it broke.
My panel truck had the same type of bolts, this is where I finally broke off the extension. I didn't want to replace the bolts with the same type with the square bolts because I planned on removing the bolts plus I didn't know if I could get replacement bolts so I ordered a set of button head Allen head bolts from McMaster-Carr. Other than the different holes, the bolts look the same and are easier to tighten using the Allen wrench, no specialt tool. You can get them in a variety of finishes too.
Just remember, if you grind anything down, to make one, grind VERY slowly, letting it cool often - heat will just make it break easier. Swipe, cool, swipe, cool...too many people grind rather quickly, and depending on whether they are making a custom tool, or sharpening a chisel/punch/drill bit, it either breaks or dulls very quickly.
Patience, grasshopper, patience...
I'm sure I'm preaching to the choir, but if ONE person learns something, it's worth the bandwidth...
R
R
JohnDigger
05-26-2014 02:33 PM
Wyowanderer
05-25-2013 05:55 PM
1983F1503004x4
03-05-2013 11:57 AM
OldSchoolRodz
09-10-2005 12:49 PM
