Running rough...
Old Jul 27, 2008 | 08:56 PM
ldcattle's Avatar
ldcattle
Running rough...
Hey guys, need some advice.
My 96 F350 has 155,000 miles and has never had a nut turned on it. Hasn't been driven 300 miles in the last 4 months (fuel prices). This morning it fired right up, I drove about 2 miles when the Check Engine light came on and it started running rough. I got on the highway, light went out and seemed OK. About 5 miles down the road, I went to turn when the light came back on and it really started running rough. Nearly died. I turned around and headed back home. Light stayed on the entire time, it shifted bad, I guess from the rough idle. Acts as though it's starving for fuel.
Fuel Pump maybe?
Any suggestions?
Thanks
ldcattle
Old Jul 27, 2008 | 09:20 PM
scatgo's Avatar
scatgo
You might want to scan for codes. It could take a lot of guess out of finding the problem.
Old Jul 28, 2008 | 12:14 AM
willbd's Avatar
willbd
My did the same thing. Burnt wiring under the valve cove gasket. Check my blog for photo's.
Willbd
Old Jul 28, 2008 | 05:30 AM
Cuda_jim's Avatar
Cuda_jim
Bad fuel??
Check your fuel filter, tell us what you find.
Old Jul 29, 2008 | 07:47 PM
ldcattle's Avatar
ldcattle
Just received a call from the mechanic. Says fuel to #5 cylinder at high demand is the problem. He's hoping when he removes the valve cover he'll find a burnt wire. If not this, he will investigate further.
Thanks
ldcattle
Old Aug 6, 2008 | 08:45 PM
ldcattle's Avatar
ldcattle
Turns out it was the wiring harness inside the valve cover.
ldcattle
