Model???
Old 06-25-2014, 06:44 PM
iperine's Avatar
iperine
iperine is offline
Question Model???
Well here I am again, STUMPED!!
I bought another old ford in hopes of restoring it. It was advertised as a 1972 f250. But I looked up how to decode the tag and under GVRW it says 09000 and under model it has F373. Does anyone know what I have???
Old 06-25-2014, 07:46 PM
iperine's Avatar
iperine
iperine is offline
Well answered my own question. It is a special order F350 with a 360 2v.
Old 06-26-2014, 02:55 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
F373 = 1972 F350 Chassis & Cab (no back of cab equipment) w/a 9,000 lb. GVWR (Gross Vehicle Weight Rating). But...why do you assume it was a special order?
Note: Compare the VIN stamped on the Warranty Plate with the VIN printed on the registration/title to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
If the VIN's do not match, F373 is probably incorrect. You can get a copy of the original build sheet from martiauto.com
Old 06-28-2014, 03:08 PM
iperine's Avatar
iperine
iperine is offline
I checked the plate does match the title. On the plate the D.S.O. is denver.
Old 06-29-2014, 01:22 PM
NumberDummy
If the DSO code only contains two digits, the truck was not a Domestic Special Order.
51 = Denver CO Ford District Sales Office, where the original selling dealer ordered the truck from.
If there were 4 additional numbers following 51, then it would have been a Domestic Special Order.
Pacecar1986
01-02-2017 05:56 PM
Oz Econoline
33
06-25-2016 12:36 PM
srisher
03-03-2015 01:57 AM
BigOldBlueTruck
04-08-2014 08:08 PM
83sd
09-02-2010 09:16 PM
Quick Reply: Model???
