easiest way to take a long box off
You can use the buddy approach mentioned or if you have access to a set of camper jacks or can borrow a set they are very handy. Lift up the bed and drive out from under. Just be sure to tripple check that everything is disconected first.
If you do not have access to a set of camper jacks or buddies to help out here is what I had to do once,
1: Disconnect everything. Including taillights.
2: Lifting one side then the other move the bed towards the back of the truck. repeat until touching tires.
3: Continue step 2 moving over rear tires until rear of bed touches ground.
4: Tilt bed up onto its tailgate. Did you remember to remove taillights?
5: Park truck back into driveway.
6: Open cooler and grab a beer.
Just curious, What are you replacing your bed with? Or are you looking to reduce weight and drag?
Uni Moe
11-27-2013 05:27 PM
tayous1
10-08-2013 11:16 PM
trintek
06-29-2007 11:30 AM
