99 v10 out 00/01 v10 in
I really don't think anything changed on the motors from 99 to 00/01 other than the heads. Someone will correct me if I'm wrong but one of those years is when Ford switched to the PI (Performance Improved) heads. So I'm thinking that sensors won't be the problem but the stock computer will need reprogrammed or swapped out.
All the PI-headed V10's I've heard of do NOT have an EGR valve, and the pre-PI headed V10's ('99) DO.
I'm pretty sure they have a DPFE (EGR flow sensor), so if you don't carry that over to the new motor, complete with exhaust manifolds (which are different), the PCM will never like it.
If it were me, and you want to fully take advantage of the newer motor, take the exhaust manifolds, leave OFF the EGR, and get the PCM (and possibly the wiring harness unless it's the same except for the DPFE sensor wiring).
'99 is pre-PI, '00 is PI.
removing the upper intake is ok.
since someone suggested removing the cab - im curious as how to do that without removing to many parts..
also i talked to the guy who owned the motor - he said the tag on valve cover has sept 1999 as the engine date.
my vehicle is dated april 1999 - so hopefully it wont be to complicated in the hook up department.
now i just have to convince the girl friend / landlord - into letting me keep the old motor in garage for a tear down.
And, disconnect the master cylinder from the power booster
The V10 dated September 1999, MIGHT BE a model-year 2000
My '01's V10 is dated sometime in September 2000 but it's a model-year 2001.
Check the heads for "PI" cast into them near the rear, under the exhaust ports. If it's a "PI" headed V10, it's a 2000-and-up.
Psyclopse
12-22-2015 12:34 PM
Olafs 7.3 ex
12-06-2015 03:05 PM
95 BRONCO XLT
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
04-20-2004 03:29 AM
