can anyone advise me on how to remove the oil pressure switch. I finally found it. i can barely get my hand to it let alone remove it. Should i remove the rad hose that is in front of it.
Get a deep socket and maybe an extension on it and just push the rad hose out of your way. It is in a tight spot for sure so even with this it won't be easy to change.
