Amp guage hook up??
Amp guage hook up??
I would use a voltmeter instead for two reasons. It gives a better indication of what your charging system is doing, the ammeter will normally hardly move. It is a lot easier to hook up.
To hookup the ammeter you have to separate the alternator output terminal and connect one side of the ammeter to the alternator output and the main supply wire for the truck. The other terminal of the ammeter goes to the start solinoid + term.
Now when you start the engine, the ammeter will show a slight charge current into the battery. If the alternator fails, the ammeter will read negative as the battery is supplying current to run the truck. Also you need to run heavy wires into the cab which should be fused. A voltmeter is just a lot easier, Just one wire to a point that is hot with the ignition on.
bronco-man
02-24-2008 05:56 PM
390hiboy
07-26-2001 10:32 PM
