How far is the speedo off with 315/75/16's?
Gears don't affect the speedo. Also, it will only be 5mph at one speed and will scale up or down from there as your speed changes.
It changes by a percentage of your speed, not by a fixed amount. Either your magellan or the speedo have an offset if you are seeing a fixed number. Check it at low speed and high speed, both with cruise set and you should not see the same mph difference. For instance, if you see 3mph difference at 30mph, you should see 6mph difference at 60mph (if tires are 10% different size than stock).
Tire Dimensions Made Simple - Discount Tire Co.
this calculator will give you a ball park setup when dealing with different speeds.
when somebody says their speedometer is off by 5 MPH I ask them - is it off by 5mph at 10 mph? Cause if it is then it is 50% off and thats nearly impossible, however if they are doing 100 then it is 5% off - lots more likely.
anyway to the original poster - consider getting an inline speed signal correction device, truspeed, speed wizard, accuspeed
I use a Speed Wizard and my speedometer agrees with my GPS by a factor of 1%, I know it is 1% cause at 100 on the GPS my speedometer looks like it is a touch under 100
as for calculating milege.... first figure out your multiply factor - new size / old size = multiply factor.
When you go to fill up use the multiply factor multiplied by miles traveled on odometer. Use that new number to get milege - but remember your speedometer may be reading incorrectly even when stock, mine did
I would suggest tracking mileage with the GPS - then you can get a better gas mileage guesstimate
thanks for reading
kenny
