motor swap???
Old Jul 15, 2008 | 07:54 AM
lennyluminum's Avatar
lennyluminum
motor swap???
will the motor from a 95 f150 fit into a 91 cougar? the f150 is a inline 6 not sure what size.
Old Jul 15, 2008 | 08:07 AM
cjben's Avatar
cjben
what motor is in the cougar? I have never heard of a v6 in a 95 f150. If the f150 motor is an inline six,you can forget about putting it in the cougar. if the f150 engine is a 5.0,it shouldn't be that hard of a swap if the cougar also has a v8,just use the electronics from the car.
Old Jul 15, 2008 | 08:11 AM
lennyluminum
yea the f150 is a inline 6 sorry about that. and the cougar is a v6 so i guess its not going to work.
Old Jul 16, 2008 | 01:31 AM
jarod17's Avatar
jarod17
With a little bit of planning and ingenuity anything can be accomplished. Carefully measure everything on both rigs and then decide if you want to. Measure twice, cut once.
Why do you want to? If you don't mind me asking.
If you do it, let us know how it turns out. I am interested.
Old Jul 16, 2008 | 02:41 AM
northern 7.3's Avatar
northern 7.3
Temporarily Deactivated
I6 wont fit in the cougar. the hoodline is WAY to low and engine bay too short. you should see the cougars/tbird's with a 4.6 in them. wow! i had one there is no room for anything else, granted the 4.6 is pretty wide but not nearly as long as a 300I6. you could however get 5.0L in the cougar from 89-93. and 4.6L 94-97. after that....the dark ages of cougars Ford probes with different sheet metal.
