Engine to Transmission Question...
Old Jul 14, 2008 | 09:10 PM
Tumblindyce's Avatar
Tumblindyce
Will an NP435 Transmission out of a 1973 F-100 mate to a 1992 351W? The Windsor has a 5-speed transmission and is in an F-250. Is the pilot bushing diameter the same? And will the length of the input shaft work? Thanks to anyone who might be able to quickly answer this question, as I am considering buying the 351 w/wiring harness and computer...I'm afraid I might miss the sale, but I need info so that I don't buy the wrong parts...
Old Jul 14, 2008 | 10:23 PM
northern 7.3's Avatar
northern 7.3
Temporarily Deactivated
what engine did the 73 have. the np 435 i believe has an 11 mm input shaft so you may have to get a diff bearing to fit depending on what trans the 351 had on it. i know i did this on a 352 and it took an alternator bearing, 4 dollars.
Old Jul 14, 2008 | 10:33 PM
Tumblindyce
Don't know which engine the '73 had. I got the transmission and bellhousing from a transmission guy...the 351 has a 1983 5-speed manual...
Old Jul 15, 2008 | 12:18 AM
85e150's Avatar
85e150
IF you have a bell that will fit the 351, a truck bell, you are good.
Of course, the clutch plate, pilot bushing must fit, but you can make that work.
IMO the best bet here is to get the 5 speed too.
Old Jul 15, 2008 | 06:01 AM
Tumblindyce
Yes I have the bellhousing that came with the NP435. Like you say, the clutch plate and even the pilot bushing weren't as much a concern as the length of the input shaft which(w/o running out to the garage to measure)I believe is 6 1/2". I may just pick up that 5-speed for future use if I make this purchase, but this Ford drivetrain would be going into a 1978 Jeep CJ-5 and I want the granny gear. Is the 5-speed from the 1983 F-250(ZF, right?)a 4-speed w/a granny low? Anyone know the ratios? Thanks.
Old Jul 15, 2008 | 10:05 AM
alxsnmr's Avatar
alxsnmr
As far as I remember the ZF 5speed didnt show up in ford trucks until ~87. The M5OD about the same time as well. But the ratios should be available for the ZF but it wont have as low of a first gear as the NP435 or T-18.
Old Jul 15, 2008 | 06:55 PM
Tumblindyce
Sorry, I said the 351 was a in a 1983 F-250...meant to say 1992.
Old Jul 15, 2008 | 10:21 PM
Tumblindyce
Follow-up question...
Sorry, if this question doesn't belong here, but can you swap a flexplate for a flywheel and use an engine that was mated to an automatic transmission if you want to use a manual transmission? In my quest for a Ford small block to bolt to my NP435, I've come across a 1985 302 w/a flexplate and torque converter...
Old Jul 16, 2008 | 02:54 AM
northern 7.3
Yes you can, just make sure the flywheel is correct for the engine. All ford engines have their crankshaft drilled for the pilot. (unlike Dodge) 302's have 2 different weight imbalances so there are 2 different flywheels. 28oz (older)
50oz (newer) Also have to make sure the pilot bushing fits the trans.
Old Jul 16, 2008 | 05:38 AM
Tumblindyce
Great news Northern. Thanks for the info...this is a very helpful forum you have here...I appreciate it.
77f100guy
Mar 20, 2022 07:16 PM
m79fordtruck
Feb 27, 2013 08:33 AM
namdorf
19
Apr 14, 2008 04:02 PM
BushyTea
Jul 7, 2007 02:34 PM
95badbird
Apr 14, 2005 12:43 PM
